Giriş
For optimal performance, the middle antenna needs to be pointed straight up and the side antennas should be angled outwards at +/- 30 degrees.
If the antennas are not staying in place, it could affect the performance of the router, and you need to be replace them.
Neye ihtiyacın var
Remove the antennas by unscrewing them from the base.
Flip over the device and locate the four rubber feet on the bottom.
Remove the rubber feet with tweezers
Detach the wires from the motherboard.
Flip the motherboard and repeat the process.
4 farklı kişi bu kılavuzu tamamladı.
