Ana içeriğe geç
Linksys EA6900 Power Port Replacement
Neye ihtiyacın var
  1. Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 1. Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 2. Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 3.
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Power Port Replacement: adım 2, 1 resimden 1.
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Power Port Replacement: adım 3, 1 resimden 1.
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Power Port Replacement: adım 4, 3 resimden 1. Linksys EA6900 Power Port Replacement: adım 4, 3 resimden 2. Linksys EA6900 Power Port Replacement: adım 4, 3 resimden 3.
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Power Port Replacement, Power Port: adım 5, 2 resimden 1. Linksys EA6900 Power Port Replacement, Power Port: adım 5, 2 resimden 2.
    • Locate the power port on both sides of the motherboard.
    • The power port on the top side is in a rectangular black casing.
    • Identify the three prongs where the power port is soldered to on the reverse side.
  6. Linksys EA6900 Power Port Replacement: adım 6, 3 resimden 1. Linksys EA6900 Power Port Replacement: adım 6, 3 resimden 2. Linksys EA6900 Power Port Replacement: adım 6, 3 resimden 3.
    • Carefully apply the soldering iron on each of the three points on the bottom side of the motherboard to melt them.
    • Be careful to not touch the motherboard with the soldering iron, you can damage the circuits.
    • After you have melted and removed the solder, flip the mother board around and identify the connecting points of the power port.
    • Use a black spudger to gently separate the power port from the motherboard
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Markiewicz
267 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 797
