Ana içeriğe geç
Linksys EA6900 Router Reset Button Replacement
Neye ihtiyacın var
  1. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 1. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 2. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 3.
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Router Reset Button Replacement: adım 2, 1 resimden 1.
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Router Reset Button Replacement: adım 3, 1 resimden 1.
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Router Reset Button Replacement: adım 4, 3 resimden 1. Linksys EA6900 Router Reset Button Replacement: adım 4, 3 resimden 2. Linksys EA6900 Router Reset Button Replacement: adım 4, 3 resimden 3.
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Router Reset Button Replacement, Router Reset Button: adım 5, 2 resimden 1. Linksys EA6900 Router Reset Button Replacement, Router Reset Button: adım 5, 2 resimden 2.
    • Make sure to correctly identify the red router reset button.
    • Locate the four solder points on the other side of the motherboard.
  6. Linksys EA6900 Router Reset Button Replacement: adım 6, 2 resimden 1. Linksys EA6900 Router Reset Button Replacement: adım 6, 2 resimden 2.
    • Be careful when working with the hot soldering iron! Make sure the router motherboard is safely resting on a level and sturdy surface.
    • Carefully apply the soldering iron to the four solders. Avoid touching the motherboard with the soldering iron, this could damage the circuits.
    • Use a spudger to gently pry and remove the reset button once the solder has melted.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Rick Hsu
343 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 1,402
