Giriş
The motherboard contains all the main components. In order to physically inspect and verify operation of components the motherboard should be removed or replaced if necessary.
Neye ihtiyacın var
Be sure the ethernet and power cables are disconnected from the device.
You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
At this point, you may want to remove the antenna leads as well.
Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
Once the screws are removed, your motherboard will separate from the housing.
Bir başkası bu kılavuzu tamamladı.
