Ana içeriğe geç
Linksys WAP54g Bottom Casing/Motherboard Replacement
Neye ihtiyacın var
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: adım 1, 1 resimden 1.
    • Power down and unplug the device.
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 2, 1 resimden 1.
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 4, 1 resimden 1.
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 5, 1 resimden 1.
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 6, 1 resimden 1.
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 7, 2 resimden 1. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 7, 2 resimden 2.
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 8, 2 resimden 1. Linksys WAP54g Bottom Casing/Motherboard Replacement: adım 8, 2 resimden 2.
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: adım 9, 2 resimden 1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: adım 9, 2 resimden 2.
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
Sonuç
After the motherboard is isolated component level repairs can be made.
2 farklı kişi bu kılavuzu tamamladı.
Mathew Fuller
146 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G21
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 2,615
