Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
You will start by isolating the motherboard and then continue to make the suggested repairs by soldering.
Neye ihtiyacın var
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Unscrew the two screws that connect the motherboard to the bottom casing.
Using a soldering iron, desolder the LED lights from the bottom of the logic board.
For help with soldering or desoldering refer to ifixit's soldering guide: How To Solder and Desolder Connections
Once the soldering is complete, the device should work and the LED lights should light up.
Bir başkası bu kılavuzu tamamladı.
