Ana içeriğe geç
Linksys WAP54g Top Casing Replacement
Neye ihtiyacın var
  1. Linksys WAP54g Top Casing Replacement, Top Casing: adım 1, 1 resimden 1.
    • Power down and unplug the device.
  2. Linksys WAP54g Top Casing Replacement: adım 2, 1 resimden 1.
  3. Linksys WAP54g Top Casing Replacement: adım 3, 1 resimden 1.
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Top Casing Replacement: adım 4, 1 resimden 1.
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Top Casing Replacement: adım 5, 1 resimden 1.
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Top Casing Replacement: adım 6, 1 resimden 1.
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Top Casing Replacement: adım 7, 2 resimden 1. Linksys WAP54g Top Casing Replacement: adım 7, 2 resimden 2.
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Top Casing Replacement: adım 8, 2 resimden 1. Linksys WAP54g Top Casing Replacement: adım 8, 2 resimden 2.
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
Sonuç
From here you can take apart the rest of the router apart by following subsequent guides.
Bir başkası bu kılavuzu tamamladı.
Derek Myers
288 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G21
5 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
Philippe Gabriel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,500
