Ana içeriğe geç
Linksys WRT54G Motherboard Replacement
Neye ihtiyacın var
  1. Linksys WRT54G Motherboard Replacement, Antennas: adım 1, 1 resimden 1.
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Replacement: adım 2, 3 resimden 1. Linksys WRT54G Motherboard Replacement: adım 2, 3 resimden 2. Linksys WRT54G Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Replacement: adım 3, 3 resimden 1. Linksys WRT54G Motherboard Replacement: adım 3, 3 resimden 2. Linksys WRT54G Motherboard Replacement: adım 3, 3 resimden 3.
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Replacement, Casing: adım 4, 2 resimden 1. Linksys WRT54G Motherboard Replacement, Casing: adım 4, 2 resimden 2.
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Linksys WRT54G Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Replacement: adım 6, 2 resimden 1. Linksys WRT54G Motherboard Replacement: adım 6, 2 resimden 2.
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Replacement: adım 7, 1 resimden 1.
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Aaron Brown
163 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-7, Regan Fall 2011 Cal Poly, Team 17-7, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G7
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 3,433
