Giriş
In this guide you will remove the router's front case and begin to have access to the router's internal components.
Neye ihtiyacın var
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Bir başkası bu kılavuzu tamamladı.
