Ana içeriğe geç
Linksys WRT54GS v2 Front Case Replacement
Neye ihtiyacın var
  1. Linksys WRT54GS v2 Front Case Replacement, Front Case: adım 1, 1 resimden 1.
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Front Case Replacement: adım 2, 1 resimden 1.
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Front Case Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Front Case Replacement: adım 4, 1 resimden 1.
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Allian Roman
276 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 1,119
