Ana içeriğe geç
Linsay Model F-7HD2CORE Battery Replacement
Neye ihtiyacın var
    1. Linsay Model F-7HD2CORE Battery Replacement, Battery: adım 1, 3 resimden 1. Linsay Model F-7HD2CORE Battery Replacement, Battery: adım 1, 3 resimden 2. Linsay Model F-7HD2CORE Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Carefully insert your plastic opening tool in between the white and black sections of your device.
      • Gently pry the top screen portion from the base of the tablet.
      • Your tablet should now look like the third image.
      FixBot'a Sor
      Yorum Ekle
    2. Linsay Model F-7HD2CORE Battery Replacement: adım 2, 2 resimden 1. Linsay Model F-7HD2CORE Battery Replacement: adım 2, 2 resimden 2.
      • To completely remove the base from the top of the tablet, peel the microphone from the back.
      FixBot'a Sor
      Yorum Ekle
    3. Linsay Model F-7HD2CORE Battery Replacement: adım 3, 2 resimden 1. Linsay Model F-7HD2CORE Battery Replacement: adım 3, 2 resimden 2.
      • Remove the two pieces of tape holding the battery in place by gently peeling it off.
      FixBot'a Sor
      Yorum Ekle
    4. Linsay Model F-7HD2CORE Battery Replacement: adım 4, 1 resimden 1.
      • Using the spudger, carefully peel the battery off of the tablet panel.
      • Tape of the back of the battery will be very strong, pull gently!
      • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
      FixBot'a Sor
      Yorum Ekle
    5. Linsay Model F-7HD2CORE Battery Replacement: adım 5, 1 resimden 1.
      • To remove the battery, completely desolder the wires connected to the circuit board.
      • To reattach the new battery, you must solder the wires back on.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lindsay Byrnes
495 İtibar
2 adet Kılavuz yazıldı
Ekip
Penn State, Team 1-5, Kaschak Winter 2015 Penn State, Team 1-5, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 1,817
