Ana içeriğe geç
Lite-On LightScribe SHM-165H6S Chassis Replacement
Neye ihtiyacın var
  1. Lite-On LightScribe SHM-165H6S Chassis Replacement, Chassis: adım 1, 2 resimden 1. Lite-On LightScribe SHM-165H6S Chassis Replacement, Chassis: adım 1, 2 resimden 2.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 2, 3 resimden 1. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 2, 3 resimden 2. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 2, 3 resimden 3.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 3, 1 resimden 1.
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 4, 1 resimden 1.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 5, 2 resimden 1. Lite-On LightScribe SHM-165H6S Chassis Replacement: adım 5, 2 resimden 2.
    • Lift the top and bottom chassis straight up in order to remove them.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
James Biggs
596 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-5, Regan Fall 2011 Cal Poly, Team 6-5, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G5
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 2,838
