Ana içeriğe geç
Lite-On LightScribe SHM-165H6S Drive Belt Replacement
Neye ihtiyacın var
  1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: adım 1, 2 resimden 1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: adım 1, 2 resimden 2.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 2, 3 resimden 1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 2, 3 resimden 2. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 2, 3 resimden 3.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 3, 1 resimden 1.
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 4, 1 resimden 1.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 5, 2 resimden 1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 5, 2 resimden 2.
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: adım 6, 2 resimden 1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Extend the tray so that the belt is accessible.
    • Remove the old belt using tweezers.
  7. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 7, 2 resimden 1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: adım 7, 2 resimden 2.
    • Carefully replace with the new belt by wrapping it around the larger gear first, followed by the smaller gear.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
James Biggs
614 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-5, Regan Fall 2011 Cal Poly, Team 6-5, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G5
2 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring”  it should be less than a buck five eighty at your local big box hardware store.
Jim Mccalb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 6,675
