Giriş
If your drive is having problems opening, the drive belt may have broken or fallen out of the track and you will need to replace it.
Neye ihtiyacın var
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Extend the tray so that the belt is accessible.
Remove the old belt using tweezers.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring” it should be less than a buck five eighty at your local big box hardware store.
