Ana içeriğe geç
Lite-On iHAS324 Disc Tray Replacement
Neye ihtiyacın var
  1. Lite-On iHAS324 Disc Tray Replacement, Chassis: adım 1, 2 resimden 1. Lite-On iHAS324 Disc Tray Replacement, Chassis: adım 1, 2 resimden 2.
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Disc Tray Replacement: adım 2, 3 resimden 1. Lite-On iHAS324 Disc Tray Replacement: adım 2, 3 resimden 2. Lite-On iHAS324 Disc Tray Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Disc Tray Replacement: adım 3, 1 resimden 1.
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Disc Tray Replacement: adım 4, 1 resimden 1.
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Disc Tray Replacement: adım 5, 1 resimden 1.
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Disc Tray Replacement: adım 6, 1 resimden 1.
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Disc Tray Replacement, Disc Tray: adım 7, 2 resimden 1. Lite-On iHAS324 Disc Tray Replacement, Disc Tray: adım 7, 2 resimden 2.
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kayla Culpepper
675 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-9, Williams Spring 2015 Baylor, Team 5-9, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G9
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,049
