Ana içeriğe geç
Logitech C920 Webcam Disassembly
Neye ihtiyacın var
    1. Logitech C920 Webcam Disassembly, Logitech C920 Webcam Disassembly: adım 1, 2 resimden 1. Logitech C920 Webcam Disassembly, Logitech C920 Webcam Disassembly: adım 1, 2 resimden 2.
      • On the bottom side of the webcam, remove the stickers from both sides
      FixBot'a Sor
      Yorum Ekle
    2. Logitech C920 Webcam Disassembly: adım 2, 1 resimden 1.
      • Remove the four Phillips screws.
      • Press into the holes to unlock the side covers.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech C920 Webcam Disassembly: adım 3, 2 resimden 1. Logitech C920 Webcam Disassembly: adım 3, 2 resimden 2.
      • Once you’ve removed the side covers, unscrew all eight Phillips screws highlighted.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech C920 Webcam Disassembly: adım 4, 3 resimden 1. Logitech C920 Webcam Disassembly: adım 4, 3 resimden 2. Logitech C920 Webcam Disassembly: adım 4, 3 resimden 3.
      • Remove the lens's cover.
      • Remove the five Phillips screws of the metal bracket.
      • Remove the rubber pieces of both microphones (one on each side).
      FixBot'a Sor
      Yorum Ekle
    5. Logitech C920 Webcam Disassembly: adım 5, 1 resimden 1.
      • Carefully remove the metal supports from the webcam's base.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech C920 Webcam Disassembly: adım 6, 2 resimden 1. Logitech C920 Webcam Disassembly: adım 6, 2 resimden 2.
      • Carefully remove the base of the plastic support. Loosen the three screws that secure the electronic circuit.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech C920 Webcam Disassembly: adım 7, 1 resimden 1.
      • Disconnect the USB cable connector.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech C920 Webcam Disassembly: adım 8, 1 resimden 1.
      • Remove the electronic circuit.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech C920 Webcam Disassembly: adım 9, 2 resimden 1. Logitech C920 Webcam Disassembly: adım 9, 2 resimden 2.
      • Release the clip that secures the cable holder. Pull this cable holder out of the camera.
      FixBot'a Sor
      Yorum Ekle
    10. Logitech C920 Webcam Disassembly: adım 10, 2 resimden 1. Logitech C920 Webcam Disassembly: adım 10, 2 resimden 2.
      • Front and back images of the webcam's electronic circuit board.
      FixBot'a Sor
      Yorum Ekle
    11. Logitech C920 Webcam Disassembly: adım 11, 1 resimden 1.
      • The problem was the broken cable on the back of the camera. I've cut the faulty part and redid the connections by soldering them and insulated them with heat shrink tubes.
      FixBot'a Sor
      Yorum Ekle
    12. Logitech C920 Webcam Disassembly: adım 12, 1 resimden 1.
      • The repaired cable is reattached to the camera. Wrapped it with some masking tape. Camera tested: OK!
      • Assemble the webcam following the steps in a reverse order.
      FixBot'a Sor
      Yorum Ekle
Sonuç
43 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
pt en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Jose Gustavo Abreu Murta
5.137 İtibar
9 adet Kılavuz yazıldı
32Kılavuz Yorumları
Excellent! Helped me figure out how to get the base off to mount it to an ikea worklamp as a hacky boom.
Cory Elsmore - Yanıt Paylaş
Can you post a guide or technique of the process?
Or share some photos? (On meta.ifixit.com)
Kind-hearted, spirited Man - Yanıt Paylaş
Cory,
I did not understand your question.
This repair guide contains several photos.
Jose Gustavo Abreu Murta - Yanıt Paylaş
thanks for an excellent guide . I am now more positive that it is something I can perform now. Many thanks
Graham Klaer - Yanıt Paylaş
im having trouble releasing the 4 screws on step 3!!! the screw driver keeps slipping and i’ve tried a few and another webcam…
Dojo Mats - Sunny - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 113
Son 30 gün: 543
Her zaman: 73,041
