Giriş
This guide will allow you to remove and replace the battery inside of the Logitech Circle. This guide is fairly simple to follow, with only a few screws being between you and the battery itself. However, be sure to be careful handling the Logitech, as the battery and lens bundle is connected to the base of the circle with a ribbon that breaks relatively easily.
Neye ihtiyacın var
Wedge the plastic opening tool under the black circle lens to gently pry it off.
Remove the battery using a plastic opening tool. The battery is attached with sticky tape and will remove with gentle prying motions.
From to get an extra battery for Logitech security camera
Battery info please 🙏🏼
Go on eBay and search ‘603040 battery’.
Quale batteria comprare per sostituire quella della telecamera?
lellab72 -
6 farklı kişi bu kılavuzu tamamladı.
19 Yorum
What about circle wireless batter with the unscrewBle lens? I keep getting error in set up that the battery is too low to proceed.
I charged only the battery portion all day. Stil. Same results
Did you figure out the battery?
Where did you buy the battery? I can’t find something to replace it with :(
I measured my battery and it is 40mm x 14mm x 30mm. The space for the battery looks like I can fit something as long as 45mm. I can not find anything in the US. Going to try these: https://www.ebay.com/itm/3-7V-1200mAh-10.... Pretty annoying that I can not find something to drop in. The most challenging part of this repair is going to be wiring these two Lipos together properly. Does anyone know the voltage of the 3 wires? My battery is completely dead so I cannot get a voltage reading. I am going to have to plug the camera in, plug the battery connector in and get the voltage from there :)
Hey, did you manage to make this work? I want to order some battery and try the same thing. I understand that you need 2 from the pictures. How are they tied together? You can not see that from this tutorial.
Just like you said, Very Easy.
Now, where can we buy the battery.
Thank you for your help.
G.R. 200.12.26
Thank you very much, very good information and like you said, very easy.
Great job.
G.R
Did anyone find out what battery it is that is needed for replacement?
Help!! Battery
Where to find the battery, that is a very good question. I’m glad that I removed mine from my camera as it had started leaking inside but was not anywhere on the boards. I put it together without the battery and works fine.
So it worked without the battery?
Hi all, I found the battery replacement and followed the guide... Wonderfull, no more battery alarm. Thank you
Still looking for a battery- anyone??
Battery reference: 533-000125
available on aliexpress
Great tutorial! Thanks!
My camera is always on its charging ring, but when the battery expired the camera would not function...
So, I've now removed the battery entirely, and the camera lives again!
First of all a BIG thank you to IFIXIT for this guide.
The battery completely failed on my camera.
It went ‘offline’ and then would not work or be re-added using the app. It was dead and I could not get it to show a blue LED or bleep as it should when ‘resetting’ it.
Having read one of the comments above, I took my camera to pieces step by step as in the guide. If you do this, follow the guide carefully, particularly with regard to the fragile ribbon cable between the camera base and the electronics that you are taking out. When you reassemble the camera, make sure the ribbon cable is fully plugged into its socket.
The only thing I did not do is replace the battery. I left the camera without a battery.
Mine is always on the charging ring, so that does not matter. I never used it with just the battery.
Having taken the battery out and re-assembled the camera, it COULD then be ‘added’ again - it DID show a blue LED and it is now fully working but without a battery.
I hope that helps someone else.
G.R.
Guy Romagnoli - Yanıt
Anyone?!?! The battery please!
Mike Arango - Yanıt
