Ana içeriğe geç
Logitech Circle Battery Replacement
Neye ihtiyacın var
  1. Logitech Circle Battery Replacement, Battery: adım 1, 2 resimden 1. Logitech Circle Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
    Just like you said, Very Easy.
    Now, where can we buy the battery.
    Thank you for your help.
    G.R.
    Guy Romagnoli - Yanıt
    Anyone?!?! The battery please!
    Mike Arango - Yanıt
  2. Logitech Circle Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Battery Replacement: adım 3, 2 resimden 1. Logitech Circle Battery Replacement: adım 3, 2 resimden 2.
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Battery Replacement: adım 4, 2 resimden 1. Logitech Circle Battery Replacement: adım 4, 2 resimden 2.
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Battery Replacement: adım 5, 2 resimden 1. Logitech Circle Battery Replacement: adım 5, 2 resimden 2.
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Battery Replacement: adım 6, 2 resimden 1. Logitech Circle Battery Replacement: adım 6, 2 resimden 2.
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the battery replacement.
    I can't find the same battery, what can I get with the same characteristics? Thank you
    lellab72 - Yanıt
    Salve dov’è posso trovare il cavo a nastro che si è rotto grazi
    Vincenzo Cristofaro - Yanıt
  7. Logitech Circle Battery Replacement: adım 7, 1 resimden 1.
    • Carefully unplug the battery from the rest of the lens.
  8. Logitech Circle Battery Replacement: adım 8, 1 resimden 1.
    • Remove the battery using a plastic opening tool. The battery is attached with sticky tape and will remove with gentle prying motions.
    From to get an extra battery for Logitech security camera
    Mahnoor Khan - Yanıt
    Battery info please 🙏🏼
    Mike Arango - Yanıt
    Go on eBay and search ‘603040 battery’.
    benbiggey -
    Quale batteria comprare per sostituire quella della telecamera?
    lellab72 -
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kylie
345 İtibar
1 Kılavuz yazıldı
Ekip
19 Yorum
What about circle wireless batter with the unscrewBle lens? I keep getting error in set up that the battery is too low to proceed.
I charged only the battery portion all day. Stil. Same results
Diane Fischer - Yanıt
Did you figure out the battery?
Mike Arango -
Where did you buy the battery? I can’t find something to replace it with :(
Razvan Ciocanel - Yanıt
I measured my battery and it is 40mm x 14mm x 30mm. The space for the battery looks like I can fit something as long as 45mm. I can not find anything in the US. Going to try these: https://www.ebay.com/itm/3-7V-1200mAh-10.... Pretty annoying that I can not find something to drop in. The most challenging part of this repair is going to be wiring these two Lipos together properly. Does anyone know the voltage of the 3 wires? My battery is completely dead so I cannot get a voltage reading. I am going to have to plug the camera in, plug the battery connector in and get the voltage from there :)
Jonathan Flower - Yanıt
Hey, did you manage to make this work? I want to order some battery and try the same thing. I understand that you need 2 from the pictures. How are they tied together? You can not see that from this tutorial.
Razvan Ciocanel -
What kind of battery do I need to buy? Is it aaa?
karen c. - Yanıt
G.R. 200.12.26
Thank you very much, very good information and like you said, very easy.
Great job.
G.R
Did anyone find out what battery it is that is needed for replacement?
Chris Wilson - Yanıt
Help!! Battery
Mike Arango -
Kindly does anyone know the link where to buy the batteries?  Thank you
fabianobu - Yanıt
Where to find the battery, that is a very good question. I’m glad that I removed mine from my camera as it had started leaking inside but was not anywhere on the boards. I put it together without the battery and works fine.
rcodea - Yanıt
So it worked without the battery?
Mike Arango -
Hi all, I found the battery replacement and followed the guide... Wonderfull, no more battery alarm. Thank you
https://it.aliexpress.com/item/330479248...
Vincenzo Mileto - Yanıt
Still looking for a battery- anyone??
Mike Arango - Yanıt
lellab72 - Yanıt
Battery reference: 533-000125
available on aliexpress
Grégory SALVIGNOL - Yanıt
Great tutorial! Thanks!
My camera is always on its charging ring, but when the battery expired the camera would not function...
So, I've now removed the battery entirely, and the camera lives again!
Neil Taylor - Yanıt
First of all a BIG thank you to IFIXIT for this guide.
The battery completely failed on my camera.
It went ‘offline’ and then would not work or be re-added using the app. It was dead and I could not get it to show a blue LED or bleep as it should when ‘resetting’ it.
Having read one of the comments above, I took my camera to pieces step by step as in the guide. If you do this,  follow the guide carefully, particularly with regard to the fragile ribbon cable between the camera base and the electronics that you are taking out. When you reassemble the camera, make sure the ribbon cable is fully plugged into its socket.
The only thing I did not do is replace the battery. I left the camera without a battery.
Mine is always on the charging ring, so that does not matter. I never used it with just the battery.
Having taken the battery out and re-assembled the camera, it COULD then be ‘added’ again - it DID show a blue LED and it is now fully working but without a battery.
I hope that helps someone else.
Wayne S - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 73
Her zaman: 9,118
