Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will allow you to remove and replace the ribbon inside of the Logitech Circle. This guide is a bit more involved, as there are several screws that need to be removed and you will need to puncture the base of the Logitech in order to remove the cable. Be sure to keep the screws organized for easier reconstruction.
Neye ihtiyacın var
Wedge the plastic opening tool under the black circle lens and gently pry it off.
Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
The two pieces of the base can now be easily pulled apart.
6 Yorum
where can I buy such a cable?
kersop@gmail.com
Can you advise where to buy the correct cable?
I have cable has beark off. I need that cable.
Where can I find
