Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Wedge the plastic opening tool under the black circle lens and gently pry it off.
Remove the four 3mm Phillips #0 screws that hold down the first ring.
Remove the four 3mm Phillips #0 screws that hold down the second ring.
Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
Gently pull the ribbon cable loose from the lens/battery bundle.
Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
The two pieces of the base can now be easily pulled apart.
Gently pull the ribbon cable loose from its connection to the base.
Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
Remove the black plastic connector and the two springs from the base of the device.
Reach inside the circle and pull the ribbon cable free from the device.
6 Yorum
where can I buy such a cable?
kersop@gmail.com
Can you advise where to buy the correct cable?
I have cable has beark off. I need that cable.
Where can I find
