Ana içeriğe geç
Logitech Cube Mouse Battery Replacement
Neye ihtiyacın var
    1. Logitech Cube Mouse  Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Logitech Cube Mouse Battery Replacement/Removal
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Cube Mouse  Battery Replacement: adım 2, 1 resimden 1.
      • Peel the touchpad up from the support plate to make a 1 CM space.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech Cube Mouse  Battery Replacement: adım 3, 1 resimden 1.
      • Use a small thin object to pry outwards between the black plastic and white plastic to release two clips under the support plate.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech Cube Mouse  Battery Replacement: adım 4, 1 resimden 1.
      • After slowly releasing the two clips hinge up the touch panel 1 inch.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech Cube Mouse  Battery Replacement: adım 5, 1 resimden 1.
      • Slide the touch panel towards the back of the mouse 1CM.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech Cube Mouse  Battery Replacement: adım 6, 1 resimden 1.
      • Lift the touch panel and support plate.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech Cube Mouse  Battery Replacement: adım 7, 1 resimden 1.
      • Lift and rotate touch panel and support plate. Disconnect the touch panel connector, the other cable helps to sense touch.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech Cube Mouse  Battery Replacement: adım 8, 1 resimden 1.
      • Remove battery, battery plug from board connection, metal plate, and two screws. A notch in the plate matches a groove on the inside, removal at a angle is required.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech Cube Mouse  Battery Replacement: adım 9, 1 resimden 1.
      • Find another battery. Original is 533-000071 3.7v 240mAh 0.63IN x 1.18IN x 0.21IN or 16.002MM X 29.972MM X 5.334MM. There is some room for different lengths and widths, but height looks to be about 5.334MM. Due to my battery's width I had to bend a tab flat on the plate and only use 1 screw.
      FixBot'a Sor
      Yorum Ekle
    10. Logitech Cube Mouse  Battery Replacement: adım 10, 1 resimden 1.
      • Press the touch pad and support plate together to undo slightly peeling them apart. Attach the battery to the plate, Install plate/ battery in mouse. Plug in battery and touch panel cables, rotate touch panel and support plate back into place. Place the front tab in its slot and press the back down to attach the clips to the bar.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Unless the chosen battery is different, reassembly is in reverse order.
Brandon
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 28
Her zaman: 1,485
