Ana içeriğe geç
Logitech Dual Action Joystick Replacement
Neye ihtiyacın var
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: adım 1, 1 resimden 1.
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: adım 2, 3 resimden 1. Logitech Dual Action Joystick Replacement, Opening the controller: adım 2, 3 resimden 2. Logitech Dual Action Joystick Replacement, Opening the controller: adım 2, 3 resimden 3.
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: adım 3, 2 resimden 1. Logitech Dual Action Joystick Replacement, Replacing the joystick: adım 3, 2 resimden 2.
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
Bitiş Çizgisi
24 farklı kişi bu kılavuzu tamamladı.
Brian Neuman
1.097 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G4
4 Üyeler
5 adet Kılavuz yazıldı
5Kılavuz Yorumları
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Yanıt Paylaş
will the buttons still work if you put it all back?
Atsuku - Yanıt Paylaş
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Yanıt Paylaş
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 55
Son 30 gün: 243
Her zaman: 13,526
