Ana içeriğe geç
Logitech Dual Action Joystick Replacement
Neye ihtiyacın var
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: adım 1, 1 resimden 1.
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: adım 2, 3 resimden 1. Logitech Dual Action Joystick Replacement, Opening the controller: adım 2, 3 resimden 2. Logitech Dual Action Joystick Replacement, Opening the controller: adım 2, 3 resimden 3.
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: adım 3, 2 resimden 1. Logitech Dual Action Joystick Replacement, Replacing the joystick: adım 3, 2 resimden 2.
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
    Where can we find the replacement Analogue Sticks
    shivam sah - Yanıt
    <a href="https://www.w3schools.com/">Visit W3Schools.com!</a> foe complete network innfoemarion on the website
    nirik - Yanıt
Bitiş Çizgisi
14 farklı kişi bu kılavuzu tamamladı.
Brian Neuman
893 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G4
4 Üyeler
5 Yorum
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Yanıt
will the buttons still work if you put it all back?
Atsuku - Yanıt
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Yanıt
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 162
Her zaman: 9,849
