Ana içeriğe geç
Logitech Dual Action Triggers Repair
Neye ihtiyacın var
  1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: adım 1, 1 resimden 1.
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
  2. Logitech Dual Action Triggers Repair: adım 2, 2 resimden 1. Logitech Dual Action Triggers Repair: adım 2, 2 resimden 2.
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
  3. Logitech Dual Action Triggers Repair: adım 3, 1 resimden 1.
    • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
  4. Logitech Dual Action Triggers Repair: adım 4, 3 resimden 1. Logitech Dual Action Triggers Repair: adım 4, 3 resimden 2. Logitech Dual Action Triggers Repair: adım 4, 3 resimden 3.
    • In the center of the controller, pull upwards on the USB cord.
    • Be careful not to pull hard enough to yank the wires connecting to the logic board.
    • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
  5. Logitech Dual Action Triggers Repair: adım 5, 3 resimden 1. Logitech Dual Action Triggers Repair: adım 5, 3 resimden 2. Logitech Dual Action Triggers Repair: adım 5, 3 resimden 3.
    • To remove the triggers, push upwards from the back on them.
    • Once far enough, detach the logic board from the back cover piece and the triggers.
  6. Logitech Dual Action Triggers Repair: adım 6, 2 resimden 1. Logitech Dual Action Triggers Repair: adım 6, 2 resimden 2.
    • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
    • Look at the second picture to see where the wires go.
  7. Logitech Dual Action Triggers Repair: adım 7, 3 resimden 1. Logitech Dual Action Triggers Repair: adım 7, 3 resimden 2. Logitech Dual Action Triggers Repair: adım 7, 3 resimden 3.
    • Unscrew the screw on the trigger to remove the back cover.
    • Once removed, carefully pull the back cover off.
  8. Logitech Dual Action Triggers Repair: adım 8, 1 resimden 1.
    • The 3 wires are soldered into the 3 spots circled on the picture.
    • You can now fasten the wire into the right spot on the trigger piece.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brian Neuman
908 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G4
4 Üyeler
2 Yorum
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - Yanıt
Where can I get conductive pads for this?
Ginga - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 35
Son 30 gün: 138
Her zaman: 8,987
