Ana içeriğe geç
Logitech Dual Action disassembly
Neye ihtiyacın var
    1. Logitech Dual Action disassembly, Taking out the screws: adım 1, 1 resimden 1.
      • To get into the controller, you will need to unscrew the 7 screws on the back.
      • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Dual Action disassembly, Opening the controller: adım 2, 3 resimden 1. Logitech Dual Action disassembly, Opening the controller: adım 2, 3 resimden 2. Logitech Dual Action disassembly, Opening the controller: adım 2, 3 resimden 3.
      • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
      • Separate the top and bottom casing.
      • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
      • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech Dual Action disassembly, Cleaning the buttons: adım 3, 1 resimden 1.
      • Turn the top casing of the controller over to remove all the buttons.
      • Wipe each individual button with a piece of cloth and rubbing alcohol.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
12 farklı kişi bu kılavuzu tamamladı.
Brian Neuman
1.172 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G4
4 Üyeler
36 adet Kılavuz yazıldı
1Rehber Yorum
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 106
Her zaman: 8,691
