Ana içeriğe geç
Logitech Dual Action disassembly
Neye ihtiyacın var
  1. Logitech Dual Action disassembly, Taking out the screws: adım 1, 1 resimden 1.
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: adım 2, 3 resimden 1. Logitech Dual Action disassembly, Opening the controller: adım 2, 3 resimden 2. Logitech Dual Action disassembly, Opening the controller: adım 2, 3 resimden 3.
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: adım 3, 1 resimden 1.
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
Bitiş Çizgisi
10 farklı kişi bu kılavuzu tamamladı.
Brian Neuman
908 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G4
4 Üyeler
Bir Yorum
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 121
Her zaman: 6,242
