Ana içeriğe geç
Logitech Extreme 3D Pro Disassembly of the base
Neye ihtiyacın var
  1. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the handle: adım 1, 1 resimden 1.
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the base: adım 2, 1 resimden 1.
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the base: adım 3, 2 resimden 1. Logitech Extreme 3D Pro Disassembly of the base: adım 3, 2 resimden 2.
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the base: adım 4, 1 resimden 1.
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Disassembly of the base: adım 5, 3 resimden 1. Logitech Extreme 3D Pro Disassembly of the base: adım 5, 3 resimden 2. Logitech Extreme 3D Pro Disassembly of the base: adım 5, 3 resimden 3.
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Emanuel Canela
1.369 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G1
4 Üyeler
2Kılavuz Yorumları
And you didn’t even finish the repair. Thanks for nothing. :(
Jesse James - Yanıt
Thank you very much
Claude1864 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 95
Her zaman: 5,258
