Ana içeriğe geç
Logitech Extreme 3D Pro Main Joystick Spring Replacement
Neye ihtiyacın var
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: adım 1, 1 resimden 1.
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 2, 1 resimden 1.
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 3, 2 resimden 1. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 3, 2 resimden 2.
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: adım 4, 1 resimden 1.
    • Remove the eight 10mm Phillips #1 screws from the bottom.
    There is a 9th screw that you need to remove near the cable
    gigakoulis - Yanıt
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 5, 3 resimden 1. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 5, 3 resimden 2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 5, 3 resimden 3.
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: adım 6, 2 resimden 1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: adım 6, 2 resimden 2.
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 7, 2 resimden 1. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 7, 2 resimden 2.
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 8, 2 resimden 1. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 8, 2 resimden 2.
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 9, 1 resimden 1.
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 10, 1 resimden 1.
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: adım 11, 1 resimden 1.
    • Remove the Spring
    • The spring will be covered in lubricant.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Emanuel Canela
1.297 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G1
4 Üyeler
6 Yorum
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - Yanıt
same question here
Robbert Sprezzatura -
Where can I find a replacement spring?
ande3224@bellsouth.net - Yanıt
Anyone found a source for replacement springs?
Chandler - Yanıt
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - Yanıt
In logitech 3d extreme, the middle joystick loosens over time, there is a slight gap when turning it to the right and left. Is there a solution to this?
haşim kadir yüksel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 144
Her zaman: 11,220
