Ana içeriğe geç
Logitech Extreme 3D Pro Top button circuit board Replacement
Neye ihtiyacın var
  1. Logitech Extreme 3D Pro Top button circuit board Replacement, Disassembly of the handle: adım 1, 1 resimden 1.
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 2, 1 resimden 1.
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 3, 2 resimden 1. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 3, 2 resimden 2.
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: adım 4, 3 resimden 1. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: adım 4, 3 resimden 2. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: adım 4, 3 resimden 3.
    • Remove the three 7mm Phillips #1 screws from the button board.
    • Remove the button board from the plastic top.
    • When taken apart the plastic buttons can fall out.
  5. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 5, 2 resimden 1. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 5, 2 resimden 2.
    • Disconnect the cable from the button board.
  6. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 6, 2 resimden 1. Logitech Extreme 3D Pro Top button circuit board Replacement: adım 6, 2 resimden 2.
    • Disconnect the smaller cable from the button board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Emanuel Canela
1.369 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G1, Passmore Spring 2018 USF Tampa, Team S7-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 2,631
