Giriş
After extended use, the USB cable may have become frayed or broken completely. This will require you to change the cable to continue using the joystick.
Neye ihtiyacın var
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
2 farklı kişi bu kılavuzu tamamladı.
6 Yorum
What type of replacement cable do I need? Where can I purchase it?
Along with Tom, I would also like to know where I can get replacement parts for this joystick. I’ve been searching for a while now and can’t seem to find any spare parts for this joystick.
Savez-vous où l'on peut trouver cette pièce à l’achat ou à la récupération?
Hey! @thetechchild I had a similar issue, couldn't find replacement parts after my cat chewed on the cable.. So I found an alternate solution, I bought some of these cables, some heat shrink tubing, and replaced the cable like this. Now I can detach a male to male USB A cable to the joystick and replace the cheap cable if it ever gets damaged again! Make sure to plug the cables into the pin connector in the exact same way that the original cable was plugged in: Green, White, Red, thin Black, thicker Black (left to right as shown in the images I linked above). I think I could have gotten a JST XH plug to better connect it, but doing the pins directly seems to be working fine for now. I'm not entirely sure if that's the correct plug, but from my research it looks like it.
Sadly same issue, tried all the linked products, looks like the design of the cables have changed. I cant get it to work even with the JST plug. Thanks for giving me a little hope though!
