Ana içeriğe geç
Logitech Folio Touch Key Repair/Replacement
Neye ihtiyacın var
    1. Logitech Folio Touch Key Repair/Replacement, Make sure you have all of the pieces: adım 1, 1 resimden 1.
      • Make sure you have all 3 peices of the key to be able to put it back together.
      • You should have: the key cap and the two plastic pieces
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Folio Touch Key Repair/Replacement, Clip the circle piece onto the keycap: adım 2, 1 resimden 1.
      • Clip the plastic piece with the circular cutout into the keycap.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech Folio Touch Key Repair/Replacement, Hook and lay the square piece in the key slot: adım 3, 2 resimden 1. Logitech Folio Touch Key Repair/Replacement, Hook and lay the square piece in the key slot: adım 3, 2 resimden 2.
      • Lay the square plastic piece in the key slot and hook the holes in place. Make sure the divot on the square piece is facing down.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech Folio Touch Key Repair/Replacement, Slide the circle piece through the square piece: adım 4, 3 resimden 1. Logitech Folio Touch Key Repair/Replacement, Slide the circle piece through the square piece: adım 4, 3 resimden 2. Logitech Folio Touch Key Repair/Replacement, Slide the circle piece through the square piece: adım 4, 3 resimden 3.
      • Slide the circle piece attached to the key cap through the square piece and try to slide it onto the hook.
      • This part may be tricky, you may need to use tweezers to lift up the square piece so you don't unhook it.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech Folio Touch Key Repair/Replacement, Push key into place: adım 5, 2 resimden 1. Logitech Folio Touch Key Repair/Replacement, Push key into place: adım 5, 2 resimden 2.
      • Finally, push down lightly on the key. Once you hear it snap into place, you should be done. Lightly shake the keyboard up and down to make sure it is securely in place.
      • If you do not hear it snap into place, and you feel resistance from it, make sure the plastic pieces are oriented the correct way.
      • If there is a snap but the key hangs upside down the plastic hooks on the keycap may be worn down. You can try to use tape to hold it in place then remove it once the keycap is in place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
If something is still not working consider reaching out to Logitech support for additional support.
Andrew Washburn
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 76
Her zaman: 235
