Ana içeriğe geç
Logitech G Cloud L2-R2 Trigger Replacement
Neye ihtiyacın var
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: adım 1, 2 resimden 1. Logitech G Cloud L2-R2 Trigger Replacement, Case: adım 1, 2 resimden 2.
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G Cloud L2-R2 Trigger Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G Cloud L2-R2 Trigger Replacement: adım 3, 2 resimden 1. Logitech G Cloud L2-R2 Trigger Replacement: adım 3, 2 resimden 2.
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G Cloud L2-R2 Trigger Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech G Cloud L2-R2 Trigger Replacement: adım 5, 2 resimden 1. Logitech G Cloud L2-R2 Trigger Replacement: adım 5, 2 resimden 2.
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: adım 6, 2 resimden 1. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 69
Her zaman: 621
