Giriş
A Logitech G Pro Superlight starts scrolling by itself. Not only does it become unusable but also extremely frustrating to the user. There may be problems like dust trapped inside, blocking the sensor from registering. It is very important to get this fixed because the scroll wheel is an important aspect of the mouse. Whether browsing or gaming it gives user many purposes of using it. This guide provides a solution by replacing the malfunctioning scroll wheel with a new one.
Caution: Turn off the mouse and disconnect the USB dongle connected to the PC before starting this guide.
Neye ihtiyacın var
Use tweezers to peel off the mouse skates on the underside of the mouse.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thanks for publishing this!
Do you replace only plastic part of wheel or plastic wheel + PCB?
Where do you order new wheel?
https://ausmodshop.com/products/modded-l... pricy, but they have full replacement pcbs with all the parts installed for you so you
Daniel G -
Thanks for the guide. Didn't need a new scroll wheel, but the disassembly guide was great.
