Ana içeriğe geç
Logitech G1 Optical Mouse Scroll Wheel Replacement
Neye ihtiyacın var
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: adım 1, 1 resimden 1.
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 2, 2 resimden 1. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 2, 2 resimden 2.
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 3, 2 resimden 1. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 3, 2 resimden 2.
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 4, 2 resimden 1. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 4, 2 resimden 2.
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 5, 2 resimden 1. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 5, 2 resimden 2.
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 6, 2 resimden 1. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 6, 2 resimden 2.
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 7, 2 resimden 1. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 7, 2 resimden 2.
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: adım 8, 1 resimden 1.
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
wooseok yang
331 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 55
Her zaman: 1,595
