Ana içeriğe geç
Logitech G27 Optical Encoder Replacement
Neye ihtiyacın var
  1. Logitech G27 Optical Encoder Replacement, Steering Wheel: adım 1, 1 resimden 1.
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G27 Optical Encoder Replacement: adım 2, 1 resimden 1.
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G27 Optical Encoder Replacement: adım 3, 1 resimden 1.
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G27 Optical Encoder Replacement: adım 4, 1 resimden 1.
    • Carefully remove the PCB board from the wheel hub.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech G27 Optical Encoder Replacement: adım 5, 1 resimden 1.
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech G27 Optical Encoder Replacement: adım 6, 1 resimden 1.
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech G27 Optical Encoder Replacement: adım 7, 1 resimden 1.
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech G27 Optical Encoder Replacement: adım 8, 1 resimden 1.
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech G27 Optical Encoder Replacement: adım 9, 1 resimden 1.
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech G27 Optical Encoder Replacement: adım 10, 1 resimden 1.
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    FixBot'a Sor
    Yorum Ekle
  11. Logitech G27 Optical Encoder Replacement: adım 11, 1 resimden 1.
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    FixBot'a Sor
    Yorum Ekle
  12. Logitech G27 Optical Encoder Replacement: adım 12, 1 resimden 1.
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  13. Logitech G27 Optical Encoder Replacement: adım 13, 2 resimden 1. Logitech G27 Optical Encoder Replacement: adım 13, 2 resimden 2.
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    FixBot'a Sor
    Yorum Ekle
  14. Logitech G27 Optical Encoder Replacement, Optical Encoder: adım 14, 2 resimden 1. Logitech G27 Optical Encoder Replacement, Optical Encoder: adım 14, 2 resimden 2.
    • After following the prerequisite guide, invert your device.
    • Remove the four center-most screws from the bottom of the device with a Phillips #1 screwdriver.
    • Invert your device back to its original position, and completely remove the motor housing from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  15. Logitech G27 Optical Encoder Replacement: adım 15, 1 resimden 1.
    • Remove the eight screws attaching the metal motor housing to the plastic with a Phillips #1 screwdriver.
    • Completely remove the motor housing from the plastic.
    • In this picture, the optical encoder is attached to the end of the right-most motor. It has a black plastic case around it for protection.
    FixBot'a Sor
    Yorum Ekle
  16. Logitech G27 Optical Encoder Replacement: adım 16, 1 resimden 1.
    • Turn the device around, and remove the three screws attaching the left most motor to the metal backing using a Phillips #1 screwdriver.
    • Completely remove the motor from the metal backing. This will make it easier to move around when replacing the optical encoder.
    FixBot'a Sor
    Yorum Ekle
  17. Logitech G27 Optical Encoder Replacement: adım 17, 2 resimden 1. Logitech G27 Optical Encoder Replacement: adım 17, 2 resimden 2.
    • Remove the white 5-pin adapter from the end of the optical encoder.
    • Use the same amount of caution with this adapter as you did with all the others: don't pull directly on the wires and wiggle it out.
    • Remove the plastic casing by prying it off with a screwdriver or a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  18. Logitech G27 Optical Encoder Replacement: adım 18, 1 resimden 1.
    • Remove the two silver screws from the underside of the optical encoder with a Phillips #0 screwdriver, and the circuit will be free from the motor and ready to replace!
    • Be careful not to bend the light or the black receiver that stick up off the board. If they don't line up, your wheel won't be able to calibrate at all and you'll have a very hard time trying to line them back up.
    FixBot'a Sor
    Yorum Ekle
  19. Logitech G27 Optical Encoder Replacement: adım 19, 3 resimden 1. Logitech G27 Optical Encoder Replacement: adım 19, 3 resimden 2. Logitech G27 Optical Encoder Replacement: adım 19, 3 resimden 3.
    • During reinstallation make sure when doing this step to align the stop on the wheel gear with the track as shown in the second and third pictures.
    • Also make sure that the metal half-circle clip is placed properly inside the slot.
    • After placing the metal clip in the slot, place the plastic cog on top of the clip and on the rail.
    FixBot'a Sor
    Yorum Ekle
Sonuç
52 farklı kişi bu kılavuzu tamamladı.
Grant Blake
1.782 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G4
4 Üyeler
25 adet Kılavuz yazıldı
35Kılavuz Yorumları
Where can you get the encoder to replace it?
invertig0 - Yanıt Paylaş
If your wheel doesn't calibrate.Then check your optical encoder. It's 90 percent of the issue You can find replacement in the ETSY with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT . They have been made like original, but with more reliable plastic. We fixed our Logitech steering wheel
Fixer - Yanıt Paylaş
Hello and thanks for the guide. I understand this might be off topic, but would you happen to know the pinout of the7-pin connector in step 5? There is no label on the pins. Thanks in advance for your time.
Georgios Arkouzis - Yanıt Paylaş
Very much appreciate your assistance & time putting this together. I Chose the expoxy route. My wheel IS BACK!
Dave - Yanıt Paylaş
Are you sure about Step 19 alignment. Some other guy with G25 says it has to be dead centre alligned otherwise you get blinking lights.And that's exactly what happens to me.
robertleskovsek - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 88
Son 30 gün: 433
Her zaman: 100,332
