Giriş
If the pedals on your G27 aren't pressing down correctly, or if they just don't feel comfortable under your feet, you will want to replace the springs in the pedals. This isn't a hard replacement to do, all you need is a screwdriver.
Neye ihtiyacın var
Remove two screws from each pedal with a 2.5mm allen wrench.
Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
Once the wires are no longer connected to the top cover, remove the cover completely.
9 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Is it possible to replace / renew the potentiometers used for gas / brake?
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
What size is the cluch spring
6cm length
2cm diameter
