Ana içeriğe geç
Logitech G29 Driving Force Paddle Assembly Replacement
Neye ihtiyacın var
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: adım 1, 1 resimden 1.
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
  2. Logitech G29 Driving Force Paddle Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Paddle Assembly Replacement: adım 3, 1 resimden 1.
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
  4. Logitech G29 Driving Force Paddle Assembly Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 30 mm screws that are behind the steering wheel.
  5. Logitech G29 Driving Force Paddle Assembly Replacement: adım 5, 1 resimden 1.
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Isaac Seagle
496 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 45
Son 30 gün: 162
Her zaman: 6,850
