Ana içeriğe geç
Logitech G29 Driving Force Pedal Replacement
Neye ihtiyacın var
  1. Logitech G29 Driving Force Pedal Replacement, Pedal: adım 1, 1 resimden 1.
    • Begin by orienting the pedal box onto its underside.
    • Remove the twelve #1 Phillips screws that secure the bottom cover to the pedals.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G29 Driving Force Pedal Replacement: adım 2, 1 resimden 1.
    • Remove the remaining twelve #0 Phillips screws from the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G29 Driving Force Pedal Replacement: adım 3, 1 resimden 1.
    • To remove the pedal, first take out the 2 Allen screws located in the middle of the pedals.
    • You only need to remove the screws out of the pedal that needs fixing. Any others can stay where they are.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G29 Driving Force Pedal Replacement: adım 4, 1 resimden 1.
    • Now that all screws are loose the back plate should be able to be removed revealing the pedals.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech G29 Driving Force Pedal Replacement: adım 5, 1 resimden 1.
    • If pedal is unresponsive start by checking the gear mesh.
    • If gear mesh is not connecting check to make sure everything is tight.
    • If gears are stripped or have broken off get replacement gears.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech G29 Driving Force Pedal Replacement: adım 6, 1 resimden 1.
    • If gears are fine check the wire connections.
    • If red wires are loose, resolder and make sure the connection is good.
    • If the black ground wire is loose, tighten it up.
    • If none of these fix the problem, source a replacement pedal.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hola. Tengo un problema en el conexionamiento desde los potenciometros hasta el conector DIM9. ¿Alguien puede pasar Esquema Electrico para poder conexionar los distintos cables en los pins correspondientes?
EckoCharliE72 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 75
Son 30 gün: 373
Her zaman: 11,426
