Ana içeriğe geç
Logitech G400s Scroll Wheel Replacement
Neye ihtiyacın var
  1. Logitech G400s Scroll Wheel Replacement, Scroll Wheel: adım 1, 1 resimden 1.
    • Use a flathead screwdriver or your fingernail to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Scroll Wheel Replacement: adım 2, 1 resimden 1.
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Scroll Wheel Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Scroll Wheel Replacement: adım 4, 1 resimden 1.
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Scroll Wheel Replacement: adım 5, 1 resimden 1.
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Scroll Wheel Replacement: adım 6, 1 resimden 1.
    • Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Max Evans
403 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-7, Eyestone Fall 2016 USF Tampa, Team 16-7, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G7
1 Üye
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 3,733
