Ana içeriğe geç
Logitech G432 Microphone Replacement
Neye ihtiyacın var
  1. Logitech G432 Microphone Replacement, Earpad Cushions: adım 1, 2 resimden 1. Logitech G432 Microphone Replacement, Earpad Cushions: adım 1, 2 resimden 2.
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Microphone Replacement, Microphone: adım 2, 3 resimden 1. Logitech G432 Microphone Replacement, Microphone: adım 2, 3 resimden 2. Logitech G432 Microphone Replacement, Microphone: adım 2, 3 resimden 3.
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Microphone Replacement: adım 3, 2 resimden 1. Logitech G432 Microphone Replacement: adım 3, 2 resimden 2.
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
    • Use an iFixit opening tool to separate the four black tabs by pushing them apart.
  4. Logitech G432 Microphone Replacement: adım 4, 2 resimden 1. Logitech G432 Microphone Replacement: adım 4, 2 resimden 2.
    • To adjust or remove the microphone piece, use a Phillips #0 Screwdriver to tighten or loosen the 1.0 mm screw that holds it in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lara Vasquez
412 İtibar
4 adet Kılavuz yazıldı
Ekip
Marist, Team 1-2, Chaterdon Spring 2023 Marist, Team 1-2, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G2
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 73
Her zaman: 1,395
