Ana içeriğe geç
Logitech G432 Speaker Replacement
Neye ihtiyacın var
    1. Logitech G432 Speaker Replacement, Earpad Cushions: adım 1, 2 resimden 1. Logitech G432 Speaker Replacement, Earpad Cushions: adım 1, 2 resimden 2.
      • Carefully lift the cushion upward using your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech G432 Speaker Replacement, Speaker: adım 2, 3 resimden 1. Logitech G432 Speaker Replacement, Speaker: adım 2, 3 resimden 2. Logitech G432 Speaker Replacement, Speaker: adım 2, 3 resimden 3.
      • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
      • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
      • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech G432 Speaker Replacement: adım 3, 1 resimden 1.
      • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech G432 Speaker Replacement: adım 4, 2 resimden 1. Logitech G432 Speaker Replacement: adım 4, 2 resimden 2.
      • Using an iFixit opening tool, separate the four black tabs by pushing them away from each other to unclip them.
      • Gently pull apart the outside shell of the headpiece to reveal the speaker.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Lara Vasquez
418 İtibar
4 adet Kılavuz yazıldı
Ekip
Marist, Team 1-2, Chaterdon Spring 2023 Marist, Team 1-2, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G2
3 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Hey, I have issues trying to remove the speaker itself from the other piece, so I cant place the new one, any suggestions?
Cristian Eduardo Ramirez Silva - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 1,466
