Giriş
Use this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech G502 Hero wired gaming mouse.
Neye ihtiyacın var
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
