Giriş
This guide shows how to replace the mouse cable for the Logitech G502 Proteus Core gaming mouse, whether it's due to a broken cable or to swap to a better paracord. It should be a relatively easy and quick repair and doesn't require any previous experience of fixing mice. Unplug your mouse before starting this repair.
Neye ihtiyacın var
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Let's say you're trying to fix your G502 without a legit logitech cord, you can just splice a usb cable and solder the correct wires to the pins. I did this twice and it works flawlessly
If you are careful enough, you don't need to remove the side button ribbon.
