Ana içeriğe geç
Logitech G533 Headphones doesnt work without USB cable
Neye ihtiyacın var
      • If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
      FixBot'a Sor
      Yorum Ekle
      • If your headphones still have a warranty, just return them to the shop.
      FixBot'a Sor
      Yorum Ekle
      • Before you start disassembling try all the guides on the official website to make sure your problem is not software-based.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech G533 Headphones  doesnt work without USB cable: adım 4, 1 resimden 1.
      • Take out the left earcup padding. Turn the right side of the earcup counterclockwise and unplug the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech G533 Headphones  doesnt work without USB cable: adım 5, 1 resimden 1.
      • Unscrew 4 screws with Torx Security TR8 bit.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech G533 Headphones  doesnt work without USB cable: adım 6, 1 resimden 1.
      • Carefully move aside the speaker. There are very thin wires connected to it and the printed circuit.
      • Unscrew the 5 screws marked on the picture with Philips 0 bit.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech G533 Headphones  doesnt work without USB cable: adım 7, 1 resimden 1.
      • Loosen the screw on the picture and slide up the black top under it.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech G533 Headphones  doesnt work without USB cable: adım 8, 1 resimden 1.
      • Take out the middle frame piece.
      • You will need to push the speaker through the frame and take out the mic off the frame.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech G533 Headphones  doesnt work without USB cable: adım 9, 1 resimden 1.
      • Here you can see that the red power cable is loosened.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech G533 Headphones  doesnt work without USB cable: adım 10, 1 resimden 1.
      • It looks like the cables are not soldered to the printed circuit. Just glued to it.
      • Scrap off the glue. I used a scalpel.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech G533 Headphones  doesnt work without USB cable: adım 11, 1 resimden 1.
      • You can plug back the battery and hold the cable in its original place.
      • Switch the power button and the power light should turn on.
      • The light will turn on after 2 seconds. You will need to keep the cable in place the whole time.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech G533 Headphones  doesnt work without USB cable: adım 12, 1 resimden 1.
      • Now you have two options. You can glue the cable back in and risk it will get loosen again. Or solder it.
      • The weld on the picture was so crappy that the cable get off when I was assembling it back. And have to redo it.
      FixBot'a Sor
      Yorum Ekle
    10. Logitech G533 Headphones  doesnt work without USB cable: adım 13, 1 resimden 1.
      • When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
      • I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kobda
437 İtibar
1 Kılavuz yazıldı
9Kılavuz Yorumları
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Sauron666 - Yanıt Paylaş
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda - Yanıt Paylaş
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel - Yanıt Paylaş
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
Daniel Barelli - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 59
Her zaman: 8,028
