Ana içeriğe geç
Logitech G602 Motherboard Replacement
Neye ihtiyacın var
  1. Logitech G602 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Logitech G602 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Logitech G602 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Use a spudger to pry off all 4 mouse feet from under the mouse.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G602 Motherboard Replacement: adım 2, 3 resimden 1. Logitech G602 Motherboard Replacement: adım 2, 3 resimden 2. Logitech G602 Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from under the mouse feet.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G602 Motherboard Replacement: adım 3, 2 resimden 1. Logitech G602 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the blue spudger to prop open the battery port.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G602 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the two AA batteries from the device.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech G602 Motherboard Replacement: adım 5, 2 resimden 1. Logitech G602 Motherboard Replacement: adım 5, 2 resimden 2.
    • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the mouse’s internal hardware.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech G602 Motherboard Replacement: adım 6, 2 resimden 1. Logitech G602 Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to grip and detach the white ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech G602 Motherboard Replacement: adım 7, 1 resimden 1.
    • Use pliers to detach the white plug from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech G602 Motherboard Replacement: adım 8, 3 resimden 1. Logitech G602 Motherboard Replacement: adım 8, 3 resimden 2. Logitech G602 Motherboard Replacement: adım 8, 3 resimden 3.
    • Use a Phillips #00 screwdriver to unscrew all 5 screws (3x5mm ) from the battery pack and motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech G602 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard from the mouse.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
So can I buy a new motherboard? Where? I don’t see one available on this site.
Kat - Yanıt Paylaş
Hi there Kat. Did you eventually find out where to get a new motherboard for your G602 mouse?
Luke Haasbroek - Yanıt Paylaş
Jerico, I’ve got a problem with my g602, as the mouse is depleting new batteries energy. I put new batteries on, and they are immediately recognized as “low batteries” by the mouse system, flashing the led indicator as low battery as well. Any thoughts?
Cristian Pereverzieff - Yanıt Paylaş
I'm having the same problem. Where you able to fix the problem?
Christopher Flynn - Yanıt Paylaş
Completed successfully.
The hardest part was to find a spare mainboard.
Brendan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 104
Her zaman: 12,692
