Ana içeriğe geç
Logitech G602 Side Motherboard Replacement
Neye ihtiyacın var
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: adım 1, 1 resimden 1.
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: adım 3, 2 resimden 1. Logitech G602 Side Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: adım 5, 2 resimden 1. Logitech G602 Side Motherboard Replacement: adım 5, 2 resimden 2.
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: adım 7, 1 resimden 1.
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: adım 8, 1 resimden 1.
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 3,668
