Giriş
A guide on how to replace the top PCB assembly on a Logitech G700s mouse.
Neye ihtiyacın var
Remove the batteries from the mouse.
Use a plastic opening tool to peel up the four mouse feet.
Remove the black pin that holds the scroll wheel to the motherboard.
The protrusion on the bottom side of the pin clicks into the dimple on the base.
I find the easiest way to remove the pin is to use the pointy end of the spudger to push on this end of the pin.
First, lift the assembly from the back (green arrow), while keeping the front clear plastic part resting on the springs (red circle).
Then, while pulling it toward the back very slightly, carefully lift the front part off the springs.
The clear front part has a hole that attaches onto a clear nibble just below the bracket (blue arrow in second picture) for the scrollwheel to pivot left and right for the left and right scroll function.
Though the pivot point isn't attached too deeply. When reassembling, align the circular marks in the front to the springs, then press the back side down into the holder and it will self align.
Remove the springs and keep them safe.
Bu adımda kullanılan alet:Desoldering Pump$3.99
Desolder the header pins. Desolder while the screws and mounting hardware in the next two steps are still attached, so the board is more stable.
Look straight down and check that there most of the solder between the pin and the sidewall is removed. Push each pin sideways to make sure it is detached.
If it looks mostly clear but the pin is still attached, try pushing the pin to the opposite wall (where it is clearly detached) with a moderate amount of force. (Do not force it too much though or you risk damaging the through hole plating)
If it doesn't budge with a moderate amount of force, try using the iron to push on the pin the same way. If it attaches to another part, then the solder isn't sucked up enough.
Optionally, you may want to mod the PCB to use a socket to connect between the top and bottom, so it will be easier to access in the future. You will need to replace or cut short the header pins. It uses 2.0mm pitch 2x7 headers. There is approximately 7.2mm between the boards. I used Molex 87758-1450 pins and Amphenol 63453-114LF socket.
Remove the two Phillips #00 screws.
Next, remove the plastic mount for scroll wheel.
The top button board can now be removed.
If you have modded your mouse to use socket instead of soldered connections, lift the board up from the locations indicated by the yellow circles to avoid breaking the PCB. When reassembling, first align the two center posts that the scroll wheel mount attaches to the holes, then press down on the header area.
6 farklı kişi bu kılavuzu tamamladı.
9Kılavuz Yorumları
lol, you broke the PCB and kept it covered with your thumb all the time as if you don’t need to desolder 14 pins before step 6…
Yes. I wonder why they excluded that part ^^,
What Youri said. Plus be warned de-soldering the pins is extremely difficult to do without the proper tools, or you risk ripping the copper solder pads of the upper board when doing so (sadly that happened to me). I’d suggest trying solder wick rather than a solder sucker as its a fiddly job.
You are also going to need some fine soldering skills when replacing the board.
Wonderful. Just skip the hardest part. Desodering the two PCBs by breaking them apart.
