Ana içeriğe geç
Logitech G710+ Disassembly
Neye ihtiyacın var
  1. Logitech G710+ Disassembly, Body: adım 1, 1 resimden 1.
    • Remove 14 Phillips screws on the bottom of the kayboard.
    • Use a plastic tool to release the clips holding the case together.
    • There are two hidden clips above the left and right arrow keys.
    • Gently pry the two halves of the case apart.
    • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G710+ Disassembly, Mother board: adım 2, 3 resimden 1. Logitech G710+ Disassembly, Mother board: adım 2, 3 resimden 2. Logitech G710+ Disassembly, Mother board: adım 2, 3 resimden 3.
    • Unscrew the one screw holding on the ground and pull out the cables.
    • A good way of getting the cables out is by putting a screwdriver right there and twisting.
    • Unscrew this screw
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G710+ Disassembly, Scroll Wheel: adım 3, 1 resimden 1.
    • The light thing comes out with a wiggle.
    • The scroll wheel on the other is harder because you have to melt or brake the supports off.
    • Then you have to get the wheel out which comes out with a very gentle wiggle.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G710+ Disassembly, Pads: adım 4, 1 resimden 1.
    • You can then take off the little pads
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jackson Poer
695 İtibar
2 adet Kılavuz yazıldı
3Kılavuz Yorumları
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - Yanıt Paylaş
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - Yanıt Paylaş
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 81
Her zaman: 9,741
