Ana içeriğe geç
Logitech G733 Battery Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Logitech G733 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently pull the right ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
    • Remove the ear pad.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G733 Battery Replacement: adım 2, 2 resimden 1. Logitech G733 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four screws that secure the speaker housing using a Phillips screwdriver.
    • Place these screws on the magnetic pad so you don't lose them.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G733 Battery Replacement: adım 3, 3 resimden 1. Logitech G733 Battery Replacement: adım 3, 3 resimden 2. Logitech G733 Battery Replacement: adım 3, 3 resimden 3.
    • Lift off the speaker housing with care not to strain the connected cable.
    • Gently wiggle the white battery cable connector side to side while pulling it out to disconnect the battery.
    • Do not pull on the wires.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G733 Battery Replacement: adım 4, 1 resimden 1.
    • Take care not to puncture, twist, or bend the battery as you pry.
    • Remove the battery, using a spudger to gently pry it up if necessary.
    • Reapply adhesive, put the new battery in place, and plug it in.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, please follow these instructions in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
Darbii Rue - Yanıt Paylaş
I fully agree
Gabriel Nunes - Yanıt Paylaş
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
Heather Dasher - Yanıt Paylaş
took 2 mins to find battery info ..........................
Logi 533-000181
Stephen Burrows - Yanıt Paylaş
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
Jad Ghanayem - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 87
Her zaman: 17,293
