Ana içeriğe geç
Logitech G903 Main Mouse Feet Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Logitech G903 Main Mouse Feet Replacement, Heat the mouse foot: adım 1, 1 resimden 1.
    • If you’re planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and apply it to the bottom mouse foot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage.
  2. Logitech G903 Main Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 1. Logitech G903 Main Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 2. Logitech G903 Main Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 3.
    • Slide an opening pick under an edge of the bottom mouse foot.
    • Go slowly, and make sure the pick is underneath both the foot and its adhesive layer if you want to reuse the foot. It's easy to separate the foot from its adhesive.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide the pick under the rest of the foot until you can lift it off the mouse.
    • Remove the foot.
  3. Logitech G903 Main Mouse Feet Replacement, Clean off the old adhesive: adım 3, 3 resimden 1. Logitech G903 Main Mouse Feet Replacement, Clean off the old adhesive: adım 3, 3 resimden 2. Logitech G903 Main Mouse Feet Replacement, Clean off the old adhesive: adım 3, 3 resimden 3.
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Peel the adhesive off.
    • Before installing new feet or reinstalling old ones, wipe away any adhesive residue from the mouse with a lint-free cloth and high-concentration isopropyl alcohol.
Sonuç
Dominik Schnabelrauch
231.337 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.671 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 27
